[postgis-tickets] [PostGIS] #2181: ST_Buffer returning multipolygon with linestring input
trac at osgeo.org
Sat Jan 19 10:19:14 PST 2013
Reporter: mcastrog | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 1.5.X
Keywords: Buffer, linestring, multipolygon |
Comment(by robe):
Paul or Sandro can chime in on this, but I suspect this is not a bug and
just that your linestrings are so short. Even a buffered linestring is
not guaranteed to return a polygon if it is not simple or is really short
because at that point the areas start intersecting with each other
creating pockets which could conceivably turn into small polygons if two
pockets are close enough.
The example linestring you have has length of ~99.18 which is smaller than
your buffer.
SELECT ST_length('LINESTRING(640770.332537465
216785.425146015,640770.356311913 216785.560172686,640770.475488952
216786.226162019,640770.647396495 216787.800152365,640770.658978918
216789.268376902,640770.447752096 216792.399898366,640769.98018796
216795.624688816,640769.110287021 216798.527305023,640767.648768098
216801.891389348,640766.02448565 216804.805892778,640764.74005588
216807.134569434,640763.337363474 216809.560477487,640761.650901703
216812.246990061,640759.955600712 216815.327305019,640758.482499366
216817.868732504,640757.383693167 216819.548488661,640756.238862077
216821.226720821,640754.01503683 216824.434442434,640751.366929134
216828.435255234,640749.204368809 216832.450088865,640747.25516891
216836.227787618,640746.014020829 216838.801219168,640745.393751588
216840.360274284,640744.315976633 216842.854457673,640743.400050801
216844.65704848,640742.582575565 216846.277673322,640741.52491745
216848.478638524,640740.503835408 216850.705816576,640739.787553975
216852.270967708,640739.053289307 216853.851968469,640738.173025147
216855.546355058,640737.55488951 216856.568961104,640736.817272035
216857.822910812,640735.910795021 216859.35697228,640734.77510795
216861.236982439,640733.832969266 216862.938074642,640732.814325629
216865.039674844,640731.225095251 216869.012141189,640729.979984761
216871.879095724,640729.445974092 216873.02148841,640729.002794006
216873.679857725,640728.952197105 216873.745389857,640728.676962154
216874.089814544)'::geometry)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2181#comment:2>
