[postgis-tickets] [PostGIS] #2185: Second WKT parse crashes server
trac at osgeo.org
Wed Jan 23 14:46:04 PST 2013
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
This is an oddity that can be demonstrated two ways on my work PC:
Read valid WKT followed by invalid WKT:
postgis=# SELECT ST_AsText('POINT(3 4)');
st_astext
POINT(3 4)
(1 row)
postgis=# SELECT ST_AsText('POINT(3 4 hi)');
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Or read invalid WKT twice:
postgis=# SELECT ST_AsText('POINT Z(3 4 hi)');
ERROR: parse error - invalid geometry
HINT: "POINT Z(3 4 hi" <-- parse error at position 14 within geometry
CONTEXT: SQL function "st_astext" statement 1
Note that only the second example shows a helpful error message.
POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185>
