[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
trac at osgeo.org
Wed Jan 23 19:17:06 PST 2013
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
I just upgraded my 64-bit to 9.1.7
PostgreSQL 9.1.7, compiled by Visual C++ build 1500, 64-bit POSTGIS="2.0.1
r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.9.1, released 2012/05/15" LIBXML="2.7.8" LIBJSON="UNKNOWN" (core procs
from "2.0.0 r9605" need upgrade) RASTER (raster procs from "2.0.0 r9605"
need upgrade)
And:
SELECT ST_AsText('POINT(3 4 hi)');
ERROR: parse error - invalid geometry
HINT: "POINT(3 4 hi" <-- parse error at position 12 within geometry
CONTEXT: SQL function "st_astext" statement 1
Behaves as expected.
Unfortuantely I never downloaded 9.1.4 binaries, but I suspect 9.1.4 might
ahve been a bad build since #2180 was running 9.1.4 and I'm not seeing the
issue on 9.1.3 or 9.1.7.
Mike -- can you confirm what OS and build of PostgreSQL you are running.
If you are running 9.1.4 I'd like to close this out as an upstream
(probably already fixed) issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2185#comment:5>
