[postgis-tickets] [PostGIS] #657: Spheroid/Ellipsoid projection given Lat/Lon, Distance & Bearing
PostGIS trac at osgeo.org
Fri Jan 25 18:38:38 PST 2013
  Reporter:  lwilmen  |       Owner:  pramsey
      Type:  task     |      Status:  closed
  Priority:  low      |   Milestone:  PostGIS 2.0.3
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  bearing distance liblwgeom spheroid ellipsoid
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
  * milestone:  PostGIS 2.0.0 => PostGIS 2.0.3
Comment:
 fixed
 for PostGIS 2.1 at r11026 : http://postgis.net/docs/manual-
 dev/ST_Project.html
 for PostGIS 2.0 at r11027 :
 http://postgis.net/docs/manual-2.0/ST_Project.html
 The changes should update on website shortly so check back if you don't
 see them and let us know if it still needs further clarification.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/657#comment:10>
