[postgis-tickets] [PostGIS] #2188: [raster] Issue with ST_Resize percent doesn't work always for non-georeferenced affects both in db and out db
trac at osgeo.org
Sat Jan 26 11:18:40 PST 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Okay I have more pictures but these are property inspection ones in jpeg.
For this set ST_Resize using percentage doesn't seem to work:
ST_Resize(rast,0.5,0.5)
for any of them regardless of if I have outdb or indb.
However if I do pixel size like
ST_Resize(rast,100,100)
That works fine.
I'm not sure if it's related to: #2182 and possibly a windows 2008
specific issue.
I'll check on my Windows 2003 64-bit server to verify it happens on that
as well:
Any rate:
raster2pgsql -F -Y -R C:/photos/*.jpg inspection_pics_outdb | psql
raster2pgsql -F -Y C:/photos/*.jpg inspection_pics_local | psql
SELECT version() || ' ' || postgis_full_version();
-- outputs --
PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
POSTGIS="2.1.0SVN r11044" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
LIBJSON="UNKNOWN" TOPOLOGY (topology procs from "2.1.0SVN r10987" need
upgrade) RASTER
and this is on a Windows 2008 R2 64-bit VM
-- works --
SELECT ST_Resize(rast,200,200)
FROM inspection_pics_local
WHERE filename='PHOTO_1_20080101_121112.jpg'
-- returns a black image --
SELECT ST_Resize(rast,0.5,0.5)
I'm attaching one of the problem pics this one is public record
inspections so no issue attaching pic.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2188>
