[postgis-tickets] [PostGIS] #2196: ST_Intersects performs worse on 2.0 than 1.5
trac at osgeo.org
Wed Jan 30 12:55:20 PST 2013
Reporter: zwerner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
When using the same dataset and same query, Explain Analyze shows the same
query plan but the time for the filter on st_intersects takes much longer.
postgresql 8.4 with postgis 1.5.4 (trimmed to show differences):
'-> Bitmap Heap Scan on recording r (cost=2467.53..140276.51 rows=32280
width=29) (actual time=452.074..4896.323 rows=699591 loops=1)'
' Recheck Cond: ('<geom>'::geometry && geom))'
' Filter: _st_intersects('<geom>'::geometry, geom)'
' -> Bitmap Index Scan on geom_idx (cost=0.00..2459.46 rows=96841
width=0) (actual time=358.077..358.077 rows=699598 loops=1)'
' Index Cond: ('<geom>'::geometry && geom))'
postgresql 9.2 with postgis 2.0.2 (trimmed again):
'-> Bitmap Heap Scan on recording r (cost=2395.49..137026.40 rows=31248
width=29) (actual time=438.094..11424.818 rows=699591 loops=1)'
' Recheck Cond: ('<geom>'::geometry && geom)'
' -> Bitmap Index Scan on geom_idx (cost=0.00..2387.68 rows=93743
width=0) (actual time=342.217..342.217 rows=699591 loops=1)'
As you can see, the st_intersects filter takes 6.5 seconds longer than the
equivalent query on a previous version.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2196>
