[postgis-tickets] [PostGIS] #2383: [raster]: Create extension with backslash_quote off
trac at osgeo.org
Tue Jul 16 21:44:48 PDT 2013
Reporter: sbranchaw | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.4
Component: raster | Version: 2.0.x
Keywords: |
Description changed by dustymugs:
Old description:
> Problem: backslash_quote has to be on in order to create the PostGIS
> extension.
> This is an inconvenience because I have a nightly backup job that
> restores a compressed dump file to a database where backslash_quote is
> turned off for security reasons.
> To reproduce:
> 1. createdb postgis_testdb
> 2. psql postgis_testdb
> 3. SET backslash_quote = off;
> 4. CREATE EXTENSION postgis;
> Receive the error:
> postgis_testdb=# CREATE EXTENSION postgis;
> ERROR: unsafe use of \' in a string literal
> LINE 29: RAISE WARNING E'Format \'%\' is not recogniz...
> HINT: Use '' to write quotes in strings. \' is insecure in client-only
> encodings.
> QUERY:
> DECLARE
> params text[];
> rastout raster;
> BEGIN
> IF rast IS NULL THEN
> RAISE WARNING 'Cannot set georeferencing on a null raster in
> st_setgeoreference.';
> RETURN rastout;
> END IF;
> SELECT regexp_matches(georef,
> E'(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s'
> E'(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)\\s(-?\\d+(?:\\.\\d+)?)')
> INTO params;
> IF NOT FOUND THEN
> RAISE EXCEPTION 'st_setgeoreference requires a string with 6
> floating point values.';
> END IF;
> IF format = 'ESRI' THEN
> -- params array is now:
> -- {scalex, skewy, skewx, scaley, upperleftx, upperlefty}
> rastout := st_setscale(rast, params[1]::float8,
> params[4]::float8);
> rastout := st_setskew(rastout, params[3]::float8,
> params[2]::float8);
> rastout := st_setupperleft(rastout,
> params[5]::float8 - (params[1]::float8
> * 0.5),
> params[6]::float8 - (params[4]::float8
> * 0.5));
> ELSE
> IF format != 'GDAL' THEN
> RAISE WARNING E'Format \'%\' is not recognized,
> defaulting to GDAL format.', format;
> END IF;
> params[4]::float8);
> rastout := st_setskew( rastout, params[3]::float8,
> params[2]::float8);
> rastout := st_setupperleft(rastout, params[5]::float8,
> params[6]::float8);
> END IF;
> RETURN rastout;
> END;
New description:
extension.
This is an inconvenience because I have a nightly backup job that restores
a compressed dump file to a database where backslash_quote is turned off
To reproduce:
Receive the error:
encodings.
QUERY:
DECLARE
params text[];
rastout raster;
BEGIN
RETURN rastout;
END IF;
INTO params;
IF NOT FOUND THEN
END IF;
params[4]::float8);
params[2]::float8);
* 0.5),
* 0.5));
ELSE
RAISE WARNING E'Format \'%\' is not recognized, defaulting
END IF;
params[4]::float8);
params[2]::float8);
params[6]::float8);
END IF;
RETURN rastout;
END;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2383#comment:5>
