[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
trac at osgeo.org
Wed May 1 04:47:53 PDT 2013
pagc_address_parser
Reporter: robe | Owner: robe
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.0
Component: pagc_address_parser | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Okay the good news is the most trivial of functions I can come up with is
wrappable (dissolves into the main plan), but doesn't seem to allow higher
than this:
CREATE OR REPLACE FUNCTION pagc_standardize(micro text,macro text) RETURNS
stdaddr AS
SELECT standardize_address('pagc_lex'
, 'pagc_gaz'
, 'pagc_rules'
, $1, $2 ) AS std ;
language 'sql';
The bad news it has to be like that. As soon as I try to return as an OUT
param or try to throw the parse address in there, PostgreSQL refuses to
fold into the main plan and I loose the caching.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:38>
