[postgis-tickets] [PostGIS] #2260: Benchmarking speed between built-in tiger normalizer and pagc_address_parser
trac at osgeo.org
Wed May 1 13:48:52 PDT 2013
pagc_address_parser
Reporter: robe | Owner: robe
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.0
Component: pagc_address_parser | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Getting warmer. For first phase this should do fine, but still can't do
as a drop in replace for the main function without losing speed
unfortunately so it still requires different calling for users to achieve
same speed because as soon as I try to incorporate it in a plpgsql
function, I lose the cache and while I can hide some of the plumbing in
SQL functions and CASTS, an SQL function has both the beauty and ugliness
of being transparent. The transparency hurts during install because
postgres tries to validate it and will fail if address_standardizer is not
installed So to hide it in SQL functions I have to require the pagc to be
installed or wrap it in a bridge extension. None of which is all that
appealing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2260#comment:41>
