[postgis-tickets] [PostGIS] #2224: [raster]: raster2pgsql with overview generation crashes
trac at osgeo.org
Thu May 2 23:14:51 PDT 2013
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: low | Milestone: PostGIS GDAL
Component: raster | Version: trunk
Resolution: wontfix | Keywords: windows 2008
Changes (by robe):
* status: new => closed
* resolution: => wontfix
* milestone: PostGIS 2.1.0 => PostGIS GDAL
Comment:
I really think this is a GDAL issue rather than anything we can do at
momemnt and will probably be a non-issue if you are going to change to not
use overviews in future.
I'm just going to close this out as a won't fix because it will probably
moot anyway with raster2pgsql rework.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2224#comment:14>
