[postgis-tickets] [PostGIS] #2298: ST_AsGML geography crashable with monkey inputs
trac at osgeo.org
Sat May 4 07:17:33 PDT 2013
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Changes (by robe):
* owner: pramsey => colivier
* priority: medium => blocker
Comment:
for the record, this appears to be a new bug in 2.1. I ran against 2.0
and 2.0.3 doesn't even have this signature.
-- this run on 2.0.3 --
SELECT ST_AsGML(2, geography(ST_Point(-1,20)),5,5, 'monkey', 'monkey' );
-- gives notice --
ERROR: function st_asgml(integer, geography, integer, integer, unknown,
unknown) does not exist
LINE 1: SELECT ST_AsGML(2, geography(ST_Point(-1,20)),5,5, 'monkey',...
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2298#comment:1>
