[postgis-tickets] [PostGIS] #2300: Cleanup ePub formatting and generation
trac at osgeo.org
Sat May 4 19:14:19 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
As noted in #2204 we have ePub building in place now for 2.1. yeh.
The bad news is the styling is icky or at least as far as I can tell.
though I notice it looks better depending on orietation I pick in my
docbook viewer.
The coloring is uh bad. But I like the way it looks more with style than
without.
The other issues is the
make epub
command requires your images folder be in docs/images instead of
docs/html. I hope to have a work around for this before release and as
this point consider it a bug. Note for epub building, I'm using more or
less the same logic as PostgreSQL group.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2300>
