[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
trac at osgeo.org
Sun May 5 08:50:12 PDT 2013
Reporter: robe | Owner: nw
Type: enhancement | Status: assigned
Priority: high | Milestone: PostGIS Future
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
It's built on CGAL so has a lot of the goodness for 3D handling that CGAL
has but sounds like it might be a pain to compile. Olivier is supposed to
change the configure to allow this optional configure. Then all the
SFCGAL functions will be provided as a separate extension similar to what
is done with postgis_topology.
https://github.com/Oslandia/SFCGAL
I'm okay with ST_DelaunayTriangles returning TIN as long as its not the
default behavior and there is an option to get polygons if you want (so
that means that flag has to be tri-state not 2 state). The reason being
things like ST_Union and friends don't like the extended types and
extended type behavior might change in future. So then TIN would only be
useful for viewing with tin supporting outputs or manipulating with
external tools. (which is not bad but not great).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:7>
