[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
trac at osgeo.org
Sun May 5 09:34:23 PDT 2013
Reporter: colivier | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: CGAL, SFCGAL |
Comment(by colivier):
Regina,
First the previous patch is becoming a bit old,
several improvement have been made around Boston Code Sprint.
I reply to your points
a) yeap already done to separate postgis,sql and sfcgal.sql (and same with
uninstall)
b) we did too, with a PostgreSQL env var called postgis.backend to be able
to switch from one backend to an another,
without adding a new schema.
c) Humm this one we did'nt do !
I look on it at once i finalize the regress step
Thanks for the help offer !
For your information the current patch attached
I'm still quite confident to finalize it soon enough for 2.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:7>
