[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
trac at osgeo.org
Sun May 5 09:58:30 PDT 2013
Reporter: colivier | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: CGAL, SFCGAL |
Comment(by colivier):
Regina,
1) Humm your right i assume index on 3D data must be 3D Index but no way
to be sure, i remove the &&& to a safe &&
2) and 3)
As we want to have a single SQL Schema (and that 's the best option for
end user)
we need to have a single backend, able to perform the switch (i.e geos or
sfcgal).
So for some functions provided by both GEOS and SFCGAL, we need to
slightly change the prototype name in postgis.sql.in and lwgeom_geos.h.
But obviously we didn't change anything in the GEOS behaviour functions
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:9>
