[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
PostGIS trac at osgeo.org
Sun May 5 15:49:35 PDT 2013
 Reporter:  colivier      |       Owner:  colivier
     Type:  enhancement   |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 2.1.0
Component:  postgis       |     Version:  trunk
 Keywords:  CGAL, SFCGAL  |
Comment(by colivier):
 Regina,
 After have a look on configure stuff, the behaviour is indeed the same
 than raster
 (if you don't have gdal-config, you have to specify --without-raster to
 pass configure step)
 I added a more explicit error message, so now it will be:
 configure: error:  sfcgal-config cannot be found. Use --without-sfcgal or
 install sfcgal
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:15>
