[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
PostGIS trac at osgeo.org
Sun May 5 21:09:21 PDT 2013
 Reporter:  robe     |       Owner:  nw
     Type:  patch    |      Status:  assigned
 Priority:  high     |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 I doubt that would matter. The patch applied cleanly
  If I repull down it seems fine and as soon as I apply the patch it fails.
 Weirdly it fails after all the tests are done (right after the topology
 tests) almost like its failing on shutdown of cu_tester because it can't
 find my geos. I'll t ryoswapthe includes to see if it makes a difference.
 At first I though mayybe liblwgeom shouldn't ahve geos in there since I
 thought it was supposed to be self-contained, but then why an lwgeos is in
 that folder destroys that theory.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:13>
