[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
trac at osgeo.org
Sun May 5 23:53:36 PDT 2013
Reporter: robe | Owner: nw
Type: patch | Status: assigned
Priority: high | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I went ahead and committed anyway at r11361 since its the shp2pgsql-gui cu
tester that is failing. I'll monitor and see if winnie buildbot runs into
same issue to rule out just something with my paths. As noted in #2303 I'm
seeing issues with how things are included in the gui and I don't have
GEOS in my path during compile (though it works fine with other regress
parts)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:15>
