[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
trac at osgeo.org
Mon May 6 01:11:08 PDT 2013
Reporter: robe | Owner: nw
Type: patch | Status: assigned
Priority: high | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nw):
I'm sure I'm missing something, windows builds not being
something I'm familiar with, but...
x86_64-w64-mingw32-gcc ../dbfopen.o ../shpopen.o ../getopt.o
../shpcommon.o ../safileio.o ../pgsql2shp-core.o ../shp2pgsql-core.o
cu_pgsql2shp.o cu_shp2pgsql.o cu_tester.o -o cu_tester
../../liblwgeom/.libs/liblwgeom.a -lm
-Lc:/jenkins/POSTGR~1/rel/PG9~1.0W6/lib -lpq -L/c/ming64/projects/rel-
libiconv-1.13.1w64/lib -liconv -L/c/jenkins/postgresql/rel/pg9.0w64/lib
-L/c/jenkins/gdal/rel-1.9.2w64/lib -L/c/ming64/projects/gettext/rel-
gettext-0.18.1/lib -L/c/ming64/projects/rel-libiconv-1.13.1w64/lib
-lcunit
Where does this command line say to link against GEOS?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:17>
