[postgis-tickets] [PostGIS] #2118: Implement ST_Boundary(Triangle)
trac at osgeo.org
Mon May 6 01:16:53 PDT 2013
Reporter: strk | Owner: nw
Type: patch | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords: history
Comment(by strk):
I'm seeing too many changes in lwgeom-geos connectors these days.
May be worth some talk on the mailing list before it messes up too much ?
Do I understand correctly that TRIANGLES are being threated like
MULTILINESTRINGS when converted to GEOS ? Would it make more sense to
convert to polygon ? Should we expose a Triangle geometry in GEOS C-API ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2118#comment:8>
