[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
PostGIS trac at osgeo.org
Tue May 7 04:11:52 PDT 2013
  Reporter:  robe     |       Owner:  nw
      Type:  patch    |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.1.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  history
Changes (by robe):
  * keywords:  => history
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 I'm going to consider this fixed since I can compile and make check (even
 gtk again) and I ammended the docs
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:22>
