[postgis-tickets] [PostGIS] #2305: Document sfcgal functions and amendment notes for existing
PostGIS trac at osgeo.org
Tue May 7 04:19:18 PDT 2013
 Reporter:  robe           |       Owner:  colivier
     Type:  defect         |      Status:  new
 Priority:  blocker        |   Milestone:  PostGIS 2.1.0
Component:  sfcgal         |     Version:  trunk
 Keywords:  documentation  |
 Olivier,
 Since this will be installed as a separate section.  You need to put all
 the functions in a new xml file.  Lets call it reference_sfcgal.xml.
 You need only document the extra functions that are not being swapped.
 HOWEVER for functions whose behavior switches from using GEOS/PostGIS in-
 built to SFCGAL, you need to note it in the docs.
 Also you'll need to update the installation section so people know how to
 configure and compile with it.
 You can also optionally add another using_sfcgal_dataman.xml
 Maybe we can title it Using  Advanced 3D or something.
 Documentation doesn't have to be in place for 2.1.0 beta (thought would be
 nice to at least have an installation update).  HOWEVER it has to be in
 before we go into final 2.1.0 release.  This is why I've marked this as a
 blocker.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2305>
