[postgis-tickets] [PostGIS] #2314: postgis_full_version and postgis_sfcgal_version crashes service on windows 7 edb 64-bit (was: postgis_full_version crashes service on windows 7 edb 64-bit)
PostGIS trac at osgeo.org
Fri May 10 00:16:54 PDT 2013
7 edb 64-bit
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  sfcgal   |     Version:  trunk
 Keywords:           |
Changes (by robe):
  * owner:  pramsey => colivier
  * component:  postgis => sfcgal
Comment:
 I have confirmed its the sfcgal check crashing my 64-bit EDB instance.  If
 I remark out:
         BEGIN
                 SELECT postgis_sfcgal_version() INTO sfcgalver;
         EXCEPTION
                 WHEN undefined_function THEN
                         sfcgalver := NULL;
         END;
 Works fine.
 SELECT postgis_sfcgal_version();
 crashes my windows EDB 64-bit backend
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2314#comment:2>
