[postgis-tickets] [PostGIS] #1994: Deprecate all functions with underscore_names rather than CamelCase
trac at osgeo.org
Fri May 10 09:49:35 PDT 2013
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Correctly formatted now:
ST_Shift_Longitude(geometry)
ST_Combine_BBox(box2d,geometry)
ST_find_extent(text,text,text) RETURNS box2d AS
ST_find_extent(text,text) RETURNS box2d AS
ST_mem_size(geometry)
ST_3DLength_spheroid(geometry, spheroid)
ST_length_spheroid(geometry, spheroid)
ST_length2d_spheroid(geometry, spheroid)
ST_distance_spheroid(geom1 geometry, geom2 geometry,spheroid)
ST_point_inside_circle(geometry,float8,float8,float8)
ST_locate_between_measures(geometry, float8, float8)
ST_locate_along_measure(geometry, float8)
ST_Combine_BBox(box3d,geometry)
ST_distance_sphere(geom1 geometry, geom2 geometry)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1994#comment:9>
