[postgis-tickets] [PostGIS] #2320: Operator && does not detect mixed SRIDs
trac at osgeo.org
Fri May 10 18:04:51 PDT 2013
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
This has always been an issue from the beginning of time and not one that
is easy to fix. Boxes simply don't have srids so to add a check like that
would significantly slow things down. && work on the boxes of geometries
and in fact usually just touch the index if there is one and rarely the
geometry.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2320#comment:1>
