[postgis-tickets] [PostGIS] #1898: ST_DelaunayTriangles option to output as TIN
PostGIS trac at osgeo.org
Sat May 11 18:42:50 PDT 2013
  Reporter:  robe     |       Owner:  nw
      Type:  patch    |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 2.1.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  history
Changes (by robe):
 * cc: nw@… (added)
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Nathan,
 I'm reopening this ticket because I think we need to rework it so that the
 #include "lwgeom_geos.h"  is not in the lwtin.c.  strk can correct me if I
 am wrong, but I don't think any of the type constructor files should have
 a dependency on GEOS and such dependencies need to be in lwgeom_geos..
 files.
 This is currently causing issue #2322 of which I am thinking is better to
 fix the root cause especially since liblwgeom is something we plan to
 share with other projects (and are sorta already)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1898#comment:23>
