[postgis-tickets] [PostGIS] #2323: doc po builds missing sfcgal items
PostGIS trac at osgeo.org
Sat May 11 20:13:33 PDT 2013
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
 Discovered this when had to clear out the postgis doc build job because
 lwlibgeom could not be overwritten.
 So doc build fails because of this:
 po2xml ../../extras_historytable.xml extras_historytable.xml.po >
 po2xml ../../extras_tigergeocoder.xml extras_tigergeocoder.xml.po >
 po2xml ../../extras_topology.xml extras_topology.xml.po >
 extras_topology.xml
 po2xml ../../extras.xml extras.xml.po > extras.xml
 po2xml ../../faq_raster.xml faq_raster.xml.po > faq_raster.xml
 po2xml ../../faq.xml faq.xml.po > faq.xml
 po2xml ../../installation.xml installation.xml.po > installation.xml
 po2xml ../../introduction.xml introduction.xml.po > introduction.xml
 po2xml ../../performance_tips.xml performance_tips.xml.po >
 po2xml ../../reference_accessor.xml reference_accessor.xml.po >
 po2xml ../../reference_constructor.xml reference_constructor.xml.po >
 po2xml ../../reference_editor.xml reference_editor.xml.po >
 po2xml ../../reference_exception.xml reference_exception.xml.po >
 po2xml ../../reference_lrs.xml reference_lrs.xml.po > reference_lrs.xml
 po2xml ../../reference_management.xml reference_management.xml.po >
 po2xml ../../reference_measure.xml reference_measure.xml.po >
 make[1]: *** No rule to make target `reference_sfcgal.xml.po', needed by
 `reference_sfcgal.xml'.  Stop.
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/docs/branches/2.1/doc/po/it_IT'
 make: *** [local-html] Error 2
 make: Leaving directory
 make: Entering directory
 `/var/lib/jenkins/workspace/postgis/docs/branches/2.1/doc/po/pt_BR'
 rm -f html; ln -s ../../html html
 rm -f xsl; ln -s ../../xsl xsl
 make html
 make[1]: Entering directory
 po2xml ../../postgis.xml postgis.xml.po > postgis.xml
 /usr/bin/perl -lpe "s'@@LAST_RELEASE_VERSION@@'2.1.0beta2dev'g"
 postgis.xml > postgis-out.xml
 make -C html/image_src images
 make[2]: Entering directory
 `/var/lib/jenkins/workspace/postgis/docs/branches/2.1/doc/html/image_src'
 make[2]: Nothing to be done for `images'.
 make[2]: Leaving directory
 extras_topology.xml
 Creating pdf for language it_IT...
 make pdf
 make[3]: Entering directory
 make[3]: Nothing to be done for `images'.
 make[3]: Leaving directory
 make[2]: *** No rule to make target `reference_sfcgal.xml.po', needed by
 make[1]: *** [local-pdf] Error 2
 Creating pdf for language pt_BR...
 make pdf
 make: *** [pdf-localized] Error 2
 cp: cannot stat `po/*/*.pdf': No such file or directory
 I've already tagged beta 2 this will have to wait for beta3
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2323>
