[postgis-tickets] [PostGIS] #2327: [raster] ST_Drape
trac at osgeo.org
Mon May 13 12:22:03 PDT 2013
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: raster | Version: trunk
Keywords: |
Taking a geometry and a raster, return a new XYM geometry resulting from
overlaying the geometry on the raster and populating M with values from
the raster.
Reference:
http://vterrain.org/Misc/draping.html
geometry ST_Drape(
rast raster, nband int,
geom geometry,
computed_vertices boolean DEFAULT TRUE
Some things to think about before implementing...
1. XYM or XYZ output geometry: Assuming the raster is DEM, units are
typically meter or foot. If X/Y are degrees, populating Z in the DEM's
units don't make sense. Maybe a function parameter flag indicating output
should be XYZ or XYM?
2. 3D geometry with rasters: The geometry is treated as 2D. Should pixel
values be put into Z or M?
3. computed_vertices: The returning geometry should be as detailed as the
input raster. So, returning geometry will have the same vertices of the
input geometry and possibly.
4. Polygons: How to handle the interior of the polygon? Boundary is easy.
Multipolygon? TIN?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2327>
