[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
PostGIS trac at osgeo.org
Mon May 13 21:19:09 PDT 2013
 Reporter:  mwtoews     |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  PostGIS 2.0.4
Component:  postgis     |     Version:  2.0.x
 Keywords:  windows 64  |
Comment(by robe):
 Bad news its still an issue in 9.2.4 EDB windows 7 running 2.0.3. So sems
 isolated to something about 9.2. I also tried on my older 9.2.2 and had
 same issue.
 SELECT ST_AsText('POINT(3 4 hi)'); -- crash
 SELECT postgis_full_version() || ' ' || version();
 -- POSTGIS="2.0.3 r11132" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.2, compiled by Visual C++ build
 1600, 64-bit
 and also
 POSTGIS="2.0.3 r11132" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build
 1600, 64-bit
 I'll see if I can come up with a function that doesn't involve postgis to
 crash this thing to make it easier for upstream to debug and to rule out
 postgis as the culprit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:19>
