[postgis-tickets] [PostGIS] #2329: bug on backup
trac at osgeo.org
Tue May 14 14:17:12 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Just checked my update path does indeed reset the mark editable.
It should work for those running the latest micro since Tom backported a
fix that overwrites with whatever an update does: per
http://www.postgresql.org/message-id/24678.1356039709@sss.pgh.pa.us
So upgraders should get the new patch. Everyone for their own good should
be running latest patch anyway given the serious security issue fixed in
last micros.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2329#comment:2>
