[postgis-tickets] [PostGIS] #2330: SFCGAL install does not specify minimum boost required
trac at osgeo.org
Wed May 15 07:05:05 PDT 2013
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: sfcgal | Version: trunk
Keywords: |
Comment(by colivier):
Regina,
You're right footprint could be reduce.
Mickael just commited on SFCGAL some changes to do so.
Thanks in advance to test again with a fresh SFCGAL clone
Boost 1.42 (or above) is supposed to work with SFCGAL
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2330#comment:1>
