[postgis-tickets] [PostGIS] #2330: SFCGAL install does not specify minimum boost required
PostGIS trac at osgeo.org
Wed May 15 14:40:56 PDT 2013
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  sfcgal   |     Version:  trunk
 Keywords:           |
Comment(by robe):
 BTW for mingw64-w64 I ended up compiling boost with
  --build-type=complete --without-python --without-mpi
 perhaps that's the recommended to just compile with everything though
 takes much longer to compile
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2330#comment:4>
