[postgis-tickets] [PostGIS] #2333: Can't compile under mingw64 (neither mingw64 or mingw32)
trac at osgeo.org
Wed May 15 15:13:30 PDT 2013
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: sfcgal | Version: trunk
Keywords: |
Comment(by robe):
The mingw64-w32 is failing at the linker phase. For pgRouting I had to
apply a patch to boost and cgal that swoodbridge had provided me to get
pgrouting to work. I'll see if maybe I need to do the same here.
I also noticed earlier own I had two sets of mpr and gmp so I need to make
sure the includ eand lib match its picking up.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2333#comment:1>
