[postgis-tickets] [PostGIS] #2336: FIPS 20 causes wildcard expansion to wget all files
PostGIS trac at osgeo.org
Sat May 18 08:34:59 PDT 2013
 Reporter:  skipl           |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  2.0.x
 Keywords:                  |
 Postgis 2.1.0 beta 2, tiger_geocoder extension, tiger2012 dataset:
 In loader_generate_script() the pattern for generating the per-state wget
 line is '/*_' || s.state_fips.  When processing Kansas (FIPS 20), the
 expansion matches '20' in the year 2012.
 This results in downloading the entire nation from each directory (i.e.
 *_20 matches tl_2012*).  Tightening the pattern to '/tl_*_' ||
 s.state_fips does not appear to cause any problems with the rest of the
 census tiger2012 directory structure.
 PostgreSQL 9.2.4 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit POSTGIS="2.1.0beta2 r11441"
 GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0,
 released 2013/04/24" LIBXML="2.7.8" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2336>
