[postgis-tickets] [PostGIS] #2338: crash on long_xact regress in windows EDB 64-bit
trac at osgeo.org
Sat May 18 13:37:27 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.4
Component: postgis | Version: trunk
Keywords: windows64 |
I've been ignoring all these 64-bit EDB regress failures, but started to
look at them closer. This one surprised me.
This fails on both the EB 9.2 64bit and EDB 9.3beta1 64-bit and crashes
the server. I double if many people use this feature, but something to
look at.
It usually fails on this line of long_xact.sql
POSTGIS="2.1.0beta2 r11441" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel.
4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY RASTER PostgreSQL 9.3beta1,
compiled by Visual C++ build 1600, 64-bit
{{{ --line 20 for 9.3
UPDATE test_locks SET state = 'unauthorized' where id = 1;
for 9.2 POSTGIS="2.0.3 r11132" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build
1600, 64-bit
-- line 53
UPDATE test_locks SET state = 'unauthorized' where id = 2;
so evidentally some sort of memory corruption. Doesn't happen under
mingw-w64 testing or any of the 32-bit tests last I checked.
error in logs:
ERROR: UPDATE where "id" = '1' requires authorization 'auth1'
STATEMENT: UPDATE test_locks SET state = 'unauthorized' where id = 1;
LOG: server process (PID 3764) was terminated by exception 0xC0000409
This is testing on my windows 7 64-bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2338>
