[postgis-tickets] [PostGIS] #2339: PostgreSQL 9.3beta1 EDB regress failures
trac at osgeo.org
Sat May 18 14:47:04 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
As stated mingw-w64 works fine, but when tested against EDB 9.3beta1
w64-bit I see 3 regress failures. These are not just failures but
crashers.
regress (this one fails on 9.2 EDB w64 as well presumably because of the
issues we've already noted with ST_AsText and friends)
long_xact
and this last one which actually works fine on 9.2 edb 64 but fails on 9.3
beta w64 edb
sql-mm-compoundcurve
As usual raster and topology pass with flying colors.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2339>
