[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
PostGIS trac at osgeo.org
Sun May 19 22:06:12 PDT 2013
 Reporter:  mwtoews     |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  PostGIS 2.0.4
Component:  postgis     |     Version:  2.0.x
 Keywords:  windows 64  |
Comment(by robe):
 Actually I think the trick is the PG_RETURN_NULL.  I can prevent the leak
 by changing that line to a
  if ( lwgeom_parse_wkt(&lwg_parser_result, str, LW_PARSER_CHECK_ALL) ==
 LW_FAILURE )
          PG_PARSER_ERROR(lwg_parser_result);
          PG_RETURN_NULL();
 Though I had assumed the PG_PARSER_ERROR would exit the function so
 surprised that makes a difference.  You see an issue with just returning
 PG_RETURN_NULL() in these cases?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:33>
