[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
trac at osgeo.org
Mon May 20 04:56:34 PDT 2013
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords: windows 64
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Okay finally I think I can close this one out i tried on a couple of
crasher functions posed. last fix at r11482 . So should now be fixed for
both 2.0 and 2.1 branches.
I neglected to mention that I don't think this ever happened in windows
2003 9.2 edb 64-bit (or at least as I recall I couldn't trigger it) so I
suspect it may have been also memory specific that on windows 7 and
windows 2008 because of the costing metrics it was more likely to fall
into shared memory where the infection happens.
mwtoews,
If you can retest out (winnie is done building both branches I think),
that would be swell.
Now off to kill more windows 64-bit crashers :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:36>
