[postgis-tickets] [PostGIS] #2340: typmod check error crashing when in trigger on windows 64-bit EDB
PostGIS trac at osgeo.org
Mon May 20 09:10:43 PDT 2013
 Reporter:  robe      |       Owner:  robe
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.4
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
Comment(by robe):
 actually its only the geom insert that triggers a crash.  They go thru the
 same loop of code though. But I think somehow the casting of geog:geometry
 is protecting it from crashing.  If I put a bogus cast on the geometry one
 like New.geom::geography::geometry it doesn't crash.  Maybe there is
 something fundamentally wrong with ereport under windows 64 VC++ builds.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2340#comment:1>
