[postgis-tickets] [PostGIS] #1712: ST_Snap should allow optionally also snapping to segments
trac at osgeo.org
Sat May 25 14:06:11 PDT 2013
Reporter: strk | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => invalid
Comment:
I'll close this one as it doesn't really make sense to snap a point
against a line, for the sole purpose that it's NOT POSSIBLE in a finite
space. Eventually you'd be snapping the line to the projected point on it.
What I mean is that you can't obtain a "point-on-line" w/out actually
adding a vertex to the line.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1712#comment:3>
