[postgis-tickets] [PostGIS] #2344: Changing in regress caused winnie to scream
trac at osgeo.org
Sun May 26 19:10:07 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: buildbots | Version: trunk
Keywords: |
Evidentally strk decided at r11501 it was a good idea to change the
regress to use built in diff. All well and good except winnie is having a
few issues with that.
I'll check and see if its something in configuration or just some
assumption in strk's code causing the issue:
loader/Point .... failed (wkt testdiff expected obtained:
/c/jenkins/postgis/tmp/2.1.0SVN_pg9.2_geos3.4.0dev_gdal1.10.0w64/test_1_diff)
loader/PointM ... failed ( wkt test: running shp2pgsql output:
/c/jenkins/postgis/tmp/2.1.0SVN_pg9.2_geos3.4.0dev_gdal1.10.0w64/loader.err)
loader/PointZ ... failed ( wkt test: running shp2pgsql output:
loader/MultiPoint ... failed ( wkt test: running shp2pgsql output:
loader/MultiPointM ... failed ( wkt test: running shp2pgsql output:
loader/MultiPointZ ... failed ( wkt test: running shp2pgsql output:
loader/Arc ... failed ( wkt test: running shp2pgsql output:
loader/ArcM ... failed ( wkt test: running shp2pgsql output:
loader/ArcZ ... failed ( wkt test: running shp2pgsql output:
loader/Polygon ... failed ( wkt test: running shp2pgsql output:
loader/PolygonM ... failed ( wkt test: running shp2pgsql output:
loader/PolygonZ ... failed ( wkt test: running shp2pgsql output:
loader/TSTPolygon ... failed ( wkt test: running shp2pgsql output:
loader/TSIPolygon ... failed ( wkt test: running shp2pgsql output:
loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql output:
loader/PointWithSchema ..... failed (wkb testdiff expected obtained:
/c/jenkins/postgis/tmp/2.1.0SVN_pg9.2_geos3.4.0dev_gdal1.10.0w64/test_16_diff)
loader/NoTransPoint .... failed (wkt testdiff expected obtained:
/c/jenkins/postgis/tmp/2.1.0SVN_pg9.2_geos3.4.0dev_gdal1.10.0w64/test_17_diff)
loader/NotReallyMultiPoint ... failed ( wkt test: running shp2pgsql
output:
loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
output:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2344>
