[postgis-tickets] [PostGIS] #2344: Changing in regress caused winnie to scream
PostGIS trac at osgeo.org
Sun May 26 19:44:23 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.1.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Okay fails on my local dev computer as well.  As far as I can tell, its
 because the test_1_out generated by windows has CRLF breaks and the
 Point.select.expected has just unix line breaks.
 We could change the expected files back to native mode so it matches what
 is generated except that wouldn't work too well when people are building
 from tar ball.
 strk -- please set your diff to ignore line break differences, and if you
 can PLEASE REVERT YOUR CHANGES.  I can't be having these false negatives
 cloudind real issues when we are in beta especially when I have REAL
 issues to contend with.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2344#comment:3>
