[postgis-tickets] [PostGIS] #2341: [raster] ST_MapAlgebra mask parameter
trac at osgeo.org
Thu May 30 09:11:10 PDT 2013
Reporter: nclay | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by nclay):
Replying to [comment:6 dustymugs]:
> Replying to [comment:4 nclay]:
> > That is what I had in mind. I am sill working on it and should have it
ready for testing, by Monday. I have the raster iterator done and its
pixel fetcher done that considers of a mask. When you say that "Existing
distancex and distancey variants will be changed to run on top of the mask
variants since the mask ones are more flexible." My current code has it
where if the Mask parameter is null then the "old code runs", and if a
Mask is provided the 'new code is run'. Are you saying that, the code
should be cleaned up so that we create a mask,
> > mask = ARRAY[
> > [1, 1, 1],
> > [1, 1, 1]
> > [1, 1, 1]
> > To be passed mimicking the old behaviour? Or is the current branching
behaviour acceptable?
> How are you defining the SQL-level ST_MapAlgebra() function to do the
branching? If you're just appending the mask parameter to existing
function signatures, that is messy and redundant.
> As part of what I envision, the changes would also require changing
RASTER_nMapAlgebra() in rt_pg/rt_pg.c and rt_raster_iterator() in
rt_core/rt_api.c to operate upon masks instead of distances. Because of
the deep changes, I don't think a separate band pixels by mask getter
function is needed. A alternative approach would be a general utility
function that operates on a values array based upon a mask array.
> So, crudely thought out.
> rt_errorstate
> rt_util_pixel_mask(rt_pixel *pixels, int npixels, double precision
**mask, int dimx, int dimy, int weighted)
What about considering the mask in rt_pixel_set_to_array? That would save
us some iterations over the pixels.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2341#comment:9>
