[postgis-tickets] [PostGIS] #2346: Fix topology tests after GEOSSnap fixes
PostGIS trac at osgeo.org
Thu May 30 13:36:03 PDT 2013
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.4
Component:  topology  |     Version:  2.0.x
 Keywords:            |
 Since fixes in the GEOS snap algorithm some tests for topology (tolerance-
 based) are failing due to different result (better results, IMHO).
 The test needs to be tweaked to either work in both cases or only with the
 latest release.
 .. to be honest the tolerance support in topology should really be
 refactored to use SnapToGrid...
 REF: http://trac.osgeo.org/geos/ticket/501
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2346>
