[postgis-tickets] [PostGIS] #2529: Weird behavior in ST_FlipCoordinates
trac at osgeo.org
Tue Nov 5 11:51:46 PST 2013
Reporter: marcelosoaressouza | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: postgis | Version: trunk
Keywords: ST_FlipCoordinates, PostGIS, PostgreSQL |
Comment(by pramsey):
The actual problem is relatively shallow: the flip points code write into
the database core memory, using the ptarray_set_point4d to directly
manipulate the underlying coordinate storage. Point arrays since 2.0 are
outfitted with a flag that provides their read/write status: point arrays
that sit on top of core storage are supposed to be read only. The flip
coordinates code line ignores that, and we get this bug.
However, if you add in a guard, as in the ptarray_rw_patch and run
regression, you find that lots of other functions, important core
functions that have been around forever and a day, also do the same thing!
They write into core memory. The difference seems to be that they use
PG_DETOAST_DATUM_COPY instead of PG_DETOAST_DATUM when they read their
inputs. So they get a copy that they can merrily screw around with.
However, this is where we get into an inconsistency. The point arrays
read/write flag indicates not only that its OK to alter values in the
underlying storage memory, it also indicates then when freed, the point
array should free the underlying storage too. This is incompatible with
point arrays built on top of database allocated segments. As *both* the
PG_DETOAST_DATUM_COPY and PG_DETOAST_DATUM geometries are.
The "correct" fix, which should be applied to 2.2+, would be to update all
the memory-altering functions to use PG_DETOAST_DATUM and do an explicit
lwgeom_clone_deep call before they start altering their geometries. Or,
that functions like lwgeom_transform and lwgeom_flip_coordinates be
changed to create new geometries as outputs, **not** to alter their
inputs. (This would also allow us to declare their inputs const, and avoid
side-effects, always(?) a good thing)
The interim fix is just to make flip_coordinates use PG_DETOAST_DATUM_COPY
instead of PG_DETOAST_DATUM.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2529#comment:2>
