[postgis-tickets] [PostGIS] #2529: LWGEOM API for read-only PointArrays is not enforced
trac at osgeo.org
Wed Nov 6 12:06:01 PST 2013
Reporter: marcelosoaressouza | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords: ST_FlipCoordinates, PostGIS, PostgreSQL
Comment(by strk):
Doing the copy in liblwgeom would make it impossible to avoid a copy, if a
caller knows it already has a copy. A PG_DETOAST_DATUM might give you a
copy anyway, so if liblwgeom made another you'd end up with two copies for
no reason.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2529#comment:11>
