[postgis-tickets] [PostGIS] #2181: ST_Buffer returning multipolygon with linestring/polygon input (was: ST_Buffer returning multipolygon with linestring input)
PostGIS trac at osgeo.org
Tue Nov 26 05:56:09 PST 2013
 Reporter:  mcastrog                          |       Owner:  pramsey
     Type:  defect                            |      Status:  new
 Priority:  medium                            |   Milestone:  PostGIS GEOS
Component:  postgis                           |     Version:  2.0.x
 Keywords:  Buffer, linestring, multipolygon  |
Changes (by rnuske):
 * cc: rnuske (added)
  * version:  1.5.X => 2.0.x
Comment:
 Reproduced bug with relatively simple polygon.
 One of many polygons received from a colleague produces a multipolygon if
 buffered with buffer radii between 40.5 and 42.3. Other buffer radii or a
 different "start point" in the order of the vertices lead to the expected
 regular polygons without additional slivers or splinters
 Query using simplified version of problematic polygon
 SELECT ST_AsText(ST_Buffer(ST_GeomFromText('POLYGON((19.4994 56.0304,
 19.2074 56.0271, 18.9318 56.0205, 18.8957 57.9268, 20.5001 57.9498,
 20.0079 56.0369, 19.7389 56.0304, 19.4994 56.0304))'), 42.0));
 results in
 "MULTIPOLYGON(((19.7367211896429 14.0304,19.7705233164382
 14.0307820103371,19.7389 14.0304,19.7367211896429
 14.0304)),((19.9343358615234 14.0327608693757,11.7006495228381
 14.6476772442749,3.74363996706844 16.8628724567734,-3.62598135388737
 20.5924531953819,-10.1232010579226 25.6921813271142,-15.4967450996707
 31.9648295183871,-19.5387965650002 39.1678088222387,-22.093032800601
 47.0225505845648,-23.0606710500053 55.2252798327099,-23.0967710500053
 57.1315798327099,-22.4407679720923 65.3629559687913,-20.1869395043865
 73.3068939324235,-16.4224054354575 80.6563276776687,-11.2926805712663
 87.127171204565,-4.99604998629464 92.4692996575579,2.22409551437942
 96.4762176852911,10.0886674559795 98.9930413396766,18.2936676174523
 99.9224849808449,19.8980676174523 99.9454849808449,28.4228349595372
 99.1957727823327,36.6186842709601 96.7337044076271,44.1453589826341
 92.6614943931604,50.6903837894731 87.1482034616806,55.9820372870512
 80.4227198449549,59.8006326808134 72.7642568244779,61.9876382410949
 64.4907609916044,62.4522588617096 55.9457124665125,61.175205483978
 47.4838650743824,60.683005483978 45.5709650743824,58.0642841438528
 38.2686241721232,54.1472040167705 31.5724784607419,49.0654030065054
 25.7109784307067,42.9922554664985 20.8840992041937,36.1349572365661
 17.2565180409666,28.7274568016185 14.9519960913458,21.022473738028
 14.0491560723953,20.753473738028 14.0426560723953,19.9343358615234
 14.0327608693757)),((19.9358193041834 14.0326500814315,19.9475017979551
 14.0327821096145,19.9373172271422 14.0325382120551,19.9358193041834
 14.0326500814315)))"
 SELECT postgis_full_version();
 "POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0"
 LIBJSON="UNKNOWN" RASTER"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2181#comment:4>
