[postgis-tickets] [PostGIS] #2553: ST_OffsetCurve Documentation should explicitly mention variable return type
trac at osgeo.org
Tue Nov 26 14:42:24 PST 2013
Reporter: gturner | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: documentation | Version: 2.1.x
Keywords: |
In 99% of cases, ST_OffsetCurve returns a LineString, and this is the
intuitive return type. However, in the remaining 1% of cases, it in fact
returns a MultiLineString. (The fact that some of those appear to be
unjustifiably so is probably another ticket!)
In many cases, programmers would simply assign the output to a linestring.
This will cause intermittent bugs when a Multilinestring is returned.
The documentation should explicitly say that this may be the case,
allowing a programmer to allow for that possibility.
It would be good to illustrate this possibility with an example, such as a
jigsaw-tongue type structure where the width of the narrow part of the
tongue is less than twice the offset distance.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2553>
