[postgis-tickets] [PostGIS] #2555: [raster]: ST_Reclass Working with negative numbers seems broken
trac at osgeo.org
Sat Nov 30 18:29:53 PST 2013
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: raster | Version: 2.1.x
Keywords: |
I'm not sure if this is just my misunderstanding of how reclass works or
if I'm missing something. I have a temp raster in celsius*10 units and
wanted to get down to celsius by doing this:
UPDATE t SET rast = ST_Reclass(rast,1,'-9000-9000:-900-900'::text,
'32BF'::text);
Results all come out NULL, but
UPDATE t SET rast = ST_Reclass(rast,1,'0-9000:0-900'::text, '32BF'::text);
seems to work as expected
Am I missing something. If so not clear from the docs how someone can
reclassify negative numbers. There are some examples in the regress tests
though none of those seem to amp a negative to a negative number and one
even uses the letter a?
'a-100]:50-1,(-100-1000]:150-50,(1000-10000]:254-150'
what the heck does that mean?
at any rate if this is not a bug, it should be documented as its not
intuitively obvious.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2555>
