[postgis-tickets] [PostGIS] #2463: st_length on curve is on linearized geom
PostGIS trac at osgeo.org
Sun Sep 1 12:36:25 PDT 2013
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Executing:
 select st_length(st_geomFromtext('CIRCULARSTRING(0 1000,707.1067812
 707.1067812,1000 0)'));
  st_length
  1570.63862548611
 Gives same result as:
 select st_length(st_curvetoline(st_geomFromtext('CIRCULARSTRING(0
 1000,707.1067812 707.1067812,1000 0)')));
  st_length
  1570.63862548611
 The function should return the arc length and not the approximated
 linestring length.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2463>
